Firwall ID plate
Started by Chic Gray CLC #22336, November 28, 2007, 07:19:42 PM
Does anyone know where  reproduction ID plate can be made.  The aluminum plate on my car is  bent, holes in it and most importanly not correct, as the plate identifies my car as a 38 sedan and it is a  37 convertable.    I am currently doing a ground up restoration and would like to put a correst plate on it.  I suspect the previous owner put the plate on as it was affixed with screws and it should have been rivited on. Your advise and info is appreciated and thank you. Chic Gray@shaw.ca
Mark
The body tags can be reproduced IF you provide an original by A.G. Backeast which is located in Colorado.
datatags.com
