Can anyone explain the procedure for cleaning and lubricating a speedometer and attached cable from a 1958 cadillac 60 special with the entire instrument cluster out of the car and on a table. Also, what lubricants should I use and where. Thank you. Naif
If you lubricate the speedo head at all, you should use a light oil such as "clock" or "watch" oil, sparingly.
