You shouldn't need to find a reliable machine shop to make new bushings for your king-pin suspension. Rebuild kits are available from several sources such as Kanter. And Bruce is right, by the time you spend the time and effort in what will most likely be an unsuccessful attempt to "band-aid" the problem, you might just as well do a proper rebuild and have it done with.
