Manual Transmission 1938 - 1948
Started by markcapen, January 28, 2023, 12:08:36 PM
markcapen
Selling working 3 speed manual transmission currently installed in my 1941 60 Special which was installed as a temp transmission so car could be driven when restoring original transmission. $350.00 Also have parts for Engine and trim parts. 100_4000.JPG
Mark Capen
Brad Ipsen CLC #737
For anyone considering this 41 and up tail shaft and housing is not the same as 40 and back.  Internals in trans interchange to all but there are some differences in materials.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
1940 Cadillac 60S Limo
markcapen
I thought 38 thru 41 60S were all the same   when I can figure out how to upload some pictures I will do so
Sincerely
Mark Capen
Jim Stamper
     Do the 38-48 internal parts interchange to the 37 floor shift  transmission?   Jim Stamper CLC#13470
markcapen
The shop that rebuilt my transmission may be able to answer that question
Peluso Precision Automotive Mass.
https://sgp358.wixsite.com/pelusoauto
Mark Capen
markcapen
I think the image from the shop manual should help with the question of appliciability .
Mark Capen
Jay Friedman
I agree with Brad re: differences between 38-40 and 41 and later.
Most parts interchange between 37 floor shift and later.  One difference is that the countershaft diameter was increased from 15/16ths of an inch in 37 to 1 inch in 38 and later.  It is possible to bore and/or ream the two countershaft holes in the '37 case to 1 inch in diameter and install a '38 or later countershaft and countershaft (cluster) gear.
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
markcapen
Thank you for the technical background hopefully someday I will find a new home for these parts   :)
Mark Capen
markcapen
for those who are concerned about shipping the transmission lives in  Wolcott Ct.
Mark Capen
rg171352
Is the trans together or disassembled?
