Removing dip stick tube from flat head
Started by Bob Hoffmann CLC#96, August 09, 2022, 05:42:15 PM
Bob Hoffmann CLC#96
Any hints on doing this. Yes, it's being soaked.
Thanks, Bob
J. Russo
Bob,
On my 1941 there is a bracket connected to the oil dip stick tube that bolts to the engine.
John Russo
CLC Member #32828
Tom Boehm
#2
Hello Bob, please forgive me for being dense but I don't understand the problem. I assume the bottom of the dipstick tube is rusted stuck in the socket on the block? Is the engine in the car?
toybox
  I heated the boss in the block with my torch and it came right out.
harvey b
you can give it a "tap" on the top with a block of wood,try and drive it down,that will help to loosen it,or maybe try a pipe wrench and give it a twist?. harveyb
Harvey Bowness
