56 master window switch wire retainer
Started by JungleCadd, May 31, 2023, 08:27:05 PM
JungleCadd
Greetings
Looking for the wire base that plugs into the master window switch. Just need the U shaped piece.
-e
56 Eldo Seville
dn010
I was able to obtain one on eBay for my 57, it was attached to the master switch but I needed that too. You could also search for one from a Buick, I believe they were the same.
-----Dan Benedek
'81 DMC DeLorean
Lexi
Slight chance may have one. Will have a look. Clay/Lexi
Lexi
Have not been able to locate, but still looking. Thought I had a box filled with electric odds and ends like that. I did find a wiring harness think out of a 1956 SDV but not parting out stuff from it. Will keep looking for the spare parts. Clay/Lexi
JungleCadd
Quote from: Lexi on June 03, 2023, 10:34:54 PMHave not been able to locate, but still looking. Thought I had a box filled with electric odds and ends like that. I did find a wiring harness think out of a 1956 SDV but not parting out stuff from it. Will keep looking for the spare parts. Clay/Lexi
thanks!.much appreciated
56 Eldo Seville
JungleCadd
Quote from: dn010 on June 01, 2023, 10:20:27 AMI was able to obtain one on eBay for my 57, it was attached to the master switch but I needed that too. You could also search for one from a Buick, I believe they were the same.
Thanks I see one now but looks baked plus 100 clams. I saw a shot of a 57 chrysler and looks the same but just as elusive.
56 Eldo Seville
