‘78 Eldorado am/fm/cb antenna
Started by ls2gto, February 02, 2023, 12:47:07 AM
ls2gto
Hello everyone, I recently acquired a '78 Eldorado. The am/fm/cb antenna doesn't go up or down. I can hear the motor running so I'm sure that the cable is broken. Is a repair cable for this antenna available? Thanks....
cadillactim
I am not aware of any direct replacement cables specific to that antenna, but I can install a new cable, as I repair antennas.
Tim
Tim Groves
ls2gto
Thanks Tim. I'll likely be in touch when I get a chance to get the antenna off of the car.
