1946/47 skirts
Started by toybox, May 16, 2022, 01:32:47 PM
toybox
  Ok, here is a question for someone with a parts book. Are the fender skirts the same on all 46/47 models and same Rt. or Lt. hand?
        Thank you all, Tim
Jay Friedman
According to my 1935-55 Master Parts List, the fender skirts differ from right to left in all models.
However, Series 61 skirts are different from Series 62 and 60S skirts which are the same.
Series 75 skirts are different from all the above.
BTW: Cadillac calls them "Wheel Opening Shields".
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
Oliver Betker
Hello
- the difference between the left and right skirt is the position of the brackets, since they are not symmetrical, they are off-centre,
However, you can change it by welding it to the other position, and adjust the support rail with the hooks if you have two from the same side, the thin metal shield itself is already prepared for this
- The difference between 61 and 62 is the height, 62 is half an inch higher so you can make a 61 out of a 62 skirt by cutting out half an inch and welding together
- 75 has the round larger skirts, the shape that the 61/62 model had in 1941
hope it helps!
Oliver
1946 Cadillac Series 61 Coupe
1958 Chevrolet Bel Air 4door Sedan
1958 Wartburg 311 4door Sedan 900
1961 Wartburg 311 4door Sedan 1000
1963 Trabant 500 2door Sedan
1989 Trabant 601 2door Sedan
1966 Bulldozer T 100 MGP
1968 Bulldozer T 100 MGP
1998 Nissan Pickup Navara
2015 Ford Ranger Pickup
1978 MZ T 250/1
1992 Harley Davidson Fat boy
