1968 deVille Conv Elec Windows Issues
Started by Ramtins, May 16, 2022, 06:01:45 PM
Ramtins
Hi All
I have an issue with my 1968 de Ville Convertible power windows. My master switch works for all the windows (up & down and no issues). My Emergency/Lock switch works; when I use the EMERGENCY button I am able to roll windows up and down. Leaving the  switch on Normal, once the key is in the on position the windows work.
My issue is that none of my other (rh front & rear switches) power window switches work.
I have checked the power window fuse and also the relay in the front footwell and both are ok. I have tested my windows lock out switch with the ohmmeter and the switch is good.
1) Can anyone help me with explaining how does the power get to the rest of the switches? (I tested the rear driver switch (connector) with a test light and there is no power going to it.
2) When in Emergency Mode, should you be able to roll the windows up/down from other switches? If so that doesn't work either.
I greatly appreciate any help.
CadillacFanBob
If you go to search window (upper right corner) and enter: "1968 Coupe Deville electrical issues" it should bring to a post from September 05, 2017 and has wiring diagram and connectors diagram for 1968 Cadillac
topic started by BigggBender and replied by Deville68 that posted the wiring diagram and connectors.
I hope this helps,
Bob
Frankfort, Illinois
Copied and pasted below to make it easier to find ---
Offline DeVille68
Re: 1968 Coupe DeVille electrical issues
« Reply #4 on: September 09, 2017, 06:50:06 AM »
Quote
Hi Daniel
Welcome to the forum. I have attached the chassis wiring and the wiring connectors below.
I have a restoration blog where I post about my work on my 68 DeVille Convertible, check it out here: http://forums.cadillaclasalleclub.org/index.php?topic=130360.0
This post http://forums.cadillaclasalleclub.org/index.php?topic=130360.msg322626#msg322626 and this http://forums.cadillaclasalleclub.org/index.php?topic=130360.msg322669#msg322669 post cover the wiring behind the kick panel.
This one covers the ignition relay: http://forums.cadillaclasalleclub.org/index.php?topic=130360.msg322670#msg322670
Best regards,
Nicolas
* 1968 Cadillac Wiring Diagram.pdf (2796.63 kB - downloaded 275 times.)
* 1968 Cadillac Wiring Connectors.pdf (1860.13 kB - downloaded 190 times.)
« Last Edit: September 09, 2017, 06:53:31 AM by DeVille68 »
Report to moderator    Logged
