Need Help with 1959 Horn Wire
Started by Ivan Yurtin, May 23, 2022, 12:11:07 AM
Ivan Yurtin
My horn wire was missing from the steering column (previous owner just wired a button under dash). I purchased the correct wire for the horn as shown in the attachment. I believe the end with the connector goes to the horn contact button in the steering wheel. However I don't know where the other bare end of the wire connects. I don't see a connection location on the Neutral Safety Switch. If the wire is supposed to connect to the Nuetral Safety Switch and it routs down the center of the steering column, I don't see an exit point on the steering column for the wire. Possibly it connects somewhere in the steering column???? Please provide some guidance.
Ivan Yurtin
Ivan Yurtin
Michael Petti
See if this helps. It's about a 58, but I think the setup is roughly the same.
It should locate into the connector on/for the steering column.   All the wires for turn signals, horn, etc connect there.   You'll need the right pin to fit.   I think they're round.   Crimps on with a tool.   Wire color is on the electric diagram, but guessing it's red.
The button end goes under the horn on the wheel.
