how to add oil filter to 39 engine?
Started by bariman, March 31, 2023, 04:20:33 PM
bariman
My 39 Lasalle never had an oil filter and I want to add one.  I think I know where to run the discharge hose into the timing chain cover but I'm not sure where to connect the pressure side of the oil line.  I see a connection port for the oil pressure gauge and a screw slot in the front end of the block.  Where do you connect the pressurized oil line into the engine?
Thanks.
Jim Stamper
   Have you searched here for information. It has been discussed in years past.  Jim Stamper CLC#13470
Bob Hoffmann CLC#96
Hi Dennis,
 I can help. I have the original correct oil filter & instruction sheet. I believe it's complete. Please contact me directly at bobscads@comcast.net.
 Thanks, Bob
bariman
Bob
I tried to send you a personal message but your mail box is full and will not accept more messages.
thanks for your interest in my oil filter project.  I have the canister and know where to get the oil lines.  I'm not so sure about how to connect them to the block.  Do you think the instructions help with that?  Can you send a copy of the instructions?
Dennis
Bob Hoffmann CLC#96
#4
Dennis,
Don't send me a PM!! That's why I asked you to send an email. Please do that & I'll try to Help. Send me a pic of your cannister too.
 Bob
LaSalle5019
Without modifying the block, the best you can get is a partial flow solution. The source comes from the line feeding the lifters and MUST use a restriction (1/16" hole if I recall correctly) to keep from starving the lifters. It sounds like the info Bob has will provide those details.
LaSalle5019
#6
This is the setup I have but decided not to install it
It uses a banjo bolt fitting for the oil return so you don't have to drill a hole in your timing chain cover
The feed can come from any of the ports in the oil header but the fitting that feeds the filter needs to be no larger than a 1/16" hole to avoid starving the engine bearings/lifters of oil.
Here are the original instructions
