Loose steering 1955 Cadillac
Started by Cadillac Jack 82, March 22, 2023, 11:12:08 AM
Cadillac Jack 82
Recently I had my 55 CDV out for a cruise.  I noticed at times that the steering seemed somewhat sloppy and there was noticeable play (about several inches worth).  I don't drive the car very often and she sits quite a bit.  Is this a simple adjustment or should I start sourcing new components for the front end?
Tim
CLC Member #30850
1959 Cadillac CDV "Shelley"
1964 Cadillac SDV "Rosalie"
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1955 Packard Clipper
1957 Cadillac Series 62
1962 VW Bug
1962 Dodge 880
1966 Mercury Montclair
1968 Chevy Chevelle SS
1968 Plymouth Barracuda
1977 Lincoln MKV
Start with checking all the steering linkage for excess play. Also check the gear box for input/
output play, engine running wheels straight ahead. The pitman arm movement should be close to the input from the steering wheel, 2 man job of course.
Check the "rag joint" also.  They get old and tear.   Located on the steering column above the steering gear.  Check fluid levle in the PS reservoir too.
If it's low and bubbles get in it, it won't work right.
wheikkila
I would get the rag joint for sure. Most people and shops don't think to replace them.
             Thanks Wayne
James Landi
CAREFUL: It could be a bad wheel bearing... IF not regularly serviced ( wheel bearing cleaned and re-greased), old grease no longer lubricates, and the bearing seizes and starts eating through  front wheel axles-- on these models, you're likely not hearing the grinding.  Get that front end up in the air and grab each front tire and yank--- you may discover that an entire wheel and tire seem to be loosing up, whether you pull horizonally or vertically--- that's a tell tale of a soon to occur catastropic failure. SImply add my concern with a list of the above.... and include the idler and pitman arms... in ANY CASE, your next outing needs to be to a front end specialist. Don't ignore this.   Hope this helps,  James
Cadillac Jack 82
Thank you everyone.  Theres a GM specialist in town that I trust.  I'll take her over there ASAP and see what he says.  Could be that the bearings need work.
Tim
CLC Member #30850
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1962 VW Bug
1962 Dodge 880
1977 Lincoln MKV
