1957 fleetwood air adjustable rear shocks
Started by bazilman, July 22, 2020, 10:58:13 AM
bazilman
Hi gents. Can anyone recommend a pair of air adjustable rear shocks for a 57 fleetwood (pin top / pin bottom). Nearest thing I've seen is a monroe ma-739 but these only fit 61-64 fleetwood apparently. Anyone on here fitted air adjustable rear shocks to a 57 who may be able to make a recommendation ? Thank you in advance.
Craig Dunn
Tony472
Hi bazilman,
I put those Monroe 739 on my 1960. Does well. I think from 1961 they were option. Just check dimensions of your original shocks and compare to Monroe's list
Cheers
   Tony
