1948 1959 Cadillac Convertible Top Frame Bolts and Wood Bow
Started by Po3824, June 26, 2022, 08:22:22 AM
Po3824
Does anyone out there have the specs on the rear wood bow associated with the 1949 Cadillac convertible. I understand that it is also the same as the Olds.  I believe I can handle the construction including the laminated bent wood, but need the specs.  Thanks
Patrick O'Kelly
pokelly45email addresses not permitted
248-797-1383
