Cadillac 1961
Started by Mg123rules, May 27, 2023, 02:28:25 PM
Mg123rules
Hello guys I have a 1961 cadillac 62 series my issue is that when you shift the lever from park to drive it stays stuck and you have to press the gas pedal for it to move and we have replaced everything of the braking system and also the transmission do any of you guys have the same issue 😀
Once you press the gas and get it to move is it fine the rest of the day?  What makes it stick again?  Using the brakes?  Putting it in park or reverse?
Was everything in the brakes and transmission replaced because of this sticking issue?
