1942 Vacuum “windows”?
Started by V63, August 18, 2022, 12:00:05 AM
V63
I met someone today with a custom (Durham?) 1942 series 75 ...with a (now 'non working') division but originally a power "division" that I suspect must be vacuum controlled?
I know there were briefly offered vacuum powered convertible tops. He reported there was a switch in back labeled raise and lower. The car has a padded top and tiny rear window, blind quarters with leather drivers compartment...fixed seat. Grey wool rear. Side windows are crankers
Production date Oct 1941
Any thoughts?
harry s
Anything is possible especially with a custom body car. The '41 Cadillacs with  division window were electric. The motor was basically the same as a two direction heater motor which runs a cable and pulley mechanism to operate the window. There is an information sheet for the system which I can't find at the moment.     Harry
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
V63
Ok, that's probably the answer then. Electric. Thank you!
Jeff Hansen
Cadillac did make a model as you describe - series 7533F.  Yes, division windows in 1942 were electrically powered as Harry described.  All door windows were crankers.
Were you able to get a photo?
Jeff Hansen
1941 6019S Sixty Special
1942 7533 Imperial Sedan
V63
#4
F27333C5-498B-4E67-A140-C7E3CA2034F8.jpeg The owner did not seem to think it was electric??? But then he said he did not know. I offered if it was not hydroelectric or electric the only other option would be vacuum. I'm surprised that I actually had some experience with a vacuum power top and this example actually worked which really amazed me ! Not the best of ideas however.
This particular 1942 is or will be offered for sale in the NE, NYC/NJ if I understood correct.
AMAZINGLY I do know of a non formal 1942 also available in Colorado. DK green $29,999 image attached
