55 Eldorado carb smoking
Started by swimbikerun, May 11, 2022, 10:05:30 AM
swimbikerun
New to this crew. I bought a 1955 Eldorado a week ago. They said the motor and trans were rebuilt and have about 25 miles on them. Car's been sitting for about 3+ years since the rebuild. The car does a few weird things, any help would be great. It seems to lose power when going up a hill, almost like it's starving(new gas tank was installed also). The car gets hot and has stalled out on me for about 30 minutes until it cooled off. Last night I drove it and I was getting smoke out of the passenger side batwing as well as the breather cap just in front of the radiator. And the car does idle high when in neutral. Thoughts?
James Stewart
1955 Eldorado
Cadillac Jack 82
Do you know if the car was properly broken in before it sat?
Tim
CLC Member #30850
1959 Cadillac CDV "Shelley"
1964 Cadillac SDV "Rosalie"
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1955 Packard Clipper
1957 Cadillac Series 62
1962 VW Bug
1962 Dodge 880
1966 Mercury Montclair
1968 Chevy Chevelle SS
1968 Plymouth Barracuda
1977 Lincoln MKV
Jon S
#2
The loss of power and the stalling sound like "vapor lock" to me. Is the car running hot?  Smoke out of the bat wing sounds very dangerous to me as it is probably gasoline fumes from an overly rich carburetor. Smoke from the engine oil filler/ breather is normal when the engine is off. When the engine is running it should be drawing air in and blowby should be expelled from the tube at the rear of the passenger side of the engine. I assume you have checked the engine oil level.
Jon
1958 Cadillac Sedan De Ville
1981 Corvette
2004 Mustang GT
swimbikerun
Quote from: 55 CDV Fan 82 on May 11, 2022, 11:32:33 AM
I would have to say no on that. They told me it only had about 25 miles on it. Any particular way I should be driving it? So far I've just been to and from work on slow city streets.
James Stewart
1955 Eldorado
swimbikerun
Quote from: Jon S on May 11, 2022, 11:34:08 AM
Oil looks great, yes it feels like a vapor lock. I'm going to have a mechanic adjust the idle/carbs today or tomorrow. I would say the car is running hot.
James Stewart
1955 Eldorado
Jon S
Quote from: swimbikerun on May 11, 2022, 12:58:44 PM
Also have him check the timing. If it's running hot, it could be retarded.
Jon
1981 Corvette
2004 Mustang GT
wheikkila
I would check the flow in the radiator. It could be the thermostat is not opening correctly. If you have a themo gun you can check for hot and cold spots. The guns are inexpensive and work well.
                         Thanks Wayne
swimbikerun
Quote from: wheikkila on May 11, 2022, 07:38:54 PM
                         Thanks Wayne
I was just thinking that also.
James Stewart
1955 Eldorado
swimbikerun
                         Thanks Wayne
Replaced the thermostat today from the 180 that was in it to a 160. Drove for about 30 and it seems really happy. Tomorrow is supposed to be quiet a bit hotter so that'll be the test. I'm also taking it in for a tune up on the carbs, timing on Tuesday. Thanks so much!
James Stewart
1955 Eldorado
Sounds like your original thermostat was sticking.  I would have stuck with the 180, if it cools with the 160 but not the 180, you have other problems.  The 180 allows more efficient engine operation and less sludge build-up.
swimbikerun
A couple new things I've noticed today. Someone abandoned the original fuel filter that comes our of the fuel pump and ran an inline fuel filter down that touches the engine case, so I think that's contributing to the vapor lock. And I'm curious if these adjustments on the carb pictures are correct as my car idles very high.
James Stewart
1955 Eldorado
