‘75 Eldorado AIR metal tubing manifold
Started by benji808, July 24, 2022, 01:05:44 PM
benji808
That's what it's called in the shop manual. It's the metal tube that connects to the AIR pump via a one-way check valve, then bridges the cylinder heads.
There appears to be a small hole in mine. Likely not a big deal but curious if there a nice used or NOS one out there.
Benjamin
If all you have is a small hole, get it welded up. I doubt that there ever were NOS replacements, and unless yours is quite deformed, fixing the hole and repainting the tube should suffice for all but a show car.
Geg Surfas
benji808
V63
When looking for replacement  ...  be advised cars with HEI (like yours) are different to accommodate the larger HEI distributor.
Big Fins
I would get a set of 1976 crank and water pump pulleys and block the holes in the heads with plugs, therefore eliminating the AIR fiasco.
That's if you aren't after total correctness.
Current:
Past and much missed:
1977 Brougham de Elegance
1972 Fleetwood Brougham
1971 Sedan de Ville
1970 de Ville Convertible
1969 Fleetwood Brougham
1969 Sedan de Ville
1959 Sedan deVille
V63
Quote from: Big Fins on August 13, 2022, 12:52:45 PMI would get a set of 1976 crank and water pump pulleys and block the holes in the heads with plugs, therefore eliminating the AIR fiasco.
Agreed,  because the air pump can be at issue anymore and it's failure causes the car to be non function as the water pump is dependent on it due to drive belt.
