‘75 Eldorado Auto Level Control
Started by benji808, August 12, 2022, 06:56:20 PM
benji808
Previous owner appears to have disconnected the ALC and added aftermarket air shocks. Me and my new mechanic friend are looking at trying to restore original function. All the original parts appear to be there.
A couple questions:
1) any general advice or things to watch out for?
2) is there a good source for rebuilt pumps, if we need one?
Thanks!
V63
#1
I have a 'used' compressor from a 1975 Eldorado with 40k miles.
$120 plus ship from 85004.
We just fill the air shocks with the shrader valve as needed.
benji808
Quote from: V63 on August 12, 2022, 09:22:13 PMI have a 'used' compressor from a 1975 Eldorado with 40k miles.
Do you feel comfortable that it's in good working order? If so I'll probably take it. Even if we can get this one working it seems to be rare enough that having a spare is a good idea. Let me know and I can PM you address and agree on method of payment.
V63
The car still had the original OEM delco shocks on it...(actually I think I still have those too ... but they leaked) the compressor was no longer hooked up.
Let me see about hooking up and see if it will run?
Will advise.
Big Fins
The biggest issues with the pumps are the reservoirs. They would retain moisture that would eat a hole at the lowest point. The 'working' parts are isolated from the reservoir and generally are very clean inside.
You can get the holes in the reservoirs brazed at any local muffler shop. If you have to, get a roll of gasket paper and make your own gaskets. These pumps are very simple once you open them up.
Current:
Past and much missed:
1977 Brougham de Elegance
1972 Fleetwood Brougham
1971 Sedan de Ville
1970 de Ville Convertible
1969 Fleetwood Brougham
1969 Sedan de Ville
1959 Sedan deVille
#5
I can concur with the internal corrosion of the reservoirs.
Pictured is one that suffered rustation, rather badly, and the internals above the body were perfect.   This one came out of a '71 that was very rusty, and I got it for parts.
The other pictures are of the one in my '72, and I found that it wasn't working because of the broken plastic actuating arm.   The one in the '71 was good, but with cleaning the corrosion out of the inside of the reservoir and sealing it by painting, it still did not work, so I left it, and just used a Schrader valve to inflate the Shocks.
Now, I am trying to resurect the one in my '72 to get it operational, and even after totally stripping it down, cleaning, inspecting and putting it back together, I can get it to hold pressure, the pump to operate, as in "ticking" which is the diaphragm moving up and down, but, the thing just will not raise pressure.   (It held pressure prior to stripping it down)
Even after doing what the Shop Manual said to do, twice, it still doesn't pump up pressure.   Back to it today to try again.   This thing is frustrating.
PS.   I see that the '75 reservoir is shorter than the '71 and '72.
hornetball
The rubber bits for the compressor are NLA.  The compressor was also used for vintage air horns.  Those pop up on E-bay from time-to-time and can be robbed for parts.
I managed to get mine actually ticking away under vacuum.  My tank was in good condition (AZ car).  Alas, still didn't produce enough pressure to function correctly.  So, I gave up and stored away the parts.  Maybe someday there will be a repair kit again . . . .
David King (kz78hy)
Here are some part numbers for those.  I have a couple of the longer ones and one short one.
David King
CLC 22014  (life)
1958 Eldorado Brougham 615
1998 Deville d'Elegance
1955 Eldorado #277
1964 Studebaker Commander
2012 Volt
CLCMRC benefactor 197
Mike Josephic CLC #3877
I had to replace the unit in my '73 Eldorado (20 years ago)
when they were still available.  After 1973 they went to a
shorter unit, but it's a direct replacement with a minor
change to the bottom bracket.  I used the shorter unit as
it was the only thing available.
There are no rebuild kits from anyone any longer as far as I know.
1955 Cadillac Eldorado
1973 Cadillac Eldorado
1995 Cadillac Seville
2004 Escalade
2011 Buick Lucerne CX
CLCMRC Museum Benefactor #38
