Right Head for 58-62 390
Started by hotrodln, April 29, 2022, 06:23:04 PM
hotrodln
OK so i bought two replacement heads for my project and both turned up cracked after they were cleaned up. Has anybody go one they would like to sell. you can text me at 518 821 3899. thanks very much Pat
Pat Prendergast
M. Bankes
Hi,
Pretty sure I have one, need to double check again now. I think we may have talked last time you where looking for one ?
Michael
Lexi
Quote from: hotrodln on April 29, 2022, 06:23:04 PM
I may have one '58 head, if Michael is unable to help you. Would have to confirm and also check to see what side it is, (if there). Clay/Lexi
I think we went over this last time.   '58 is a 365 head, not 390.  59-up 390.
It probably will fit but may need some other parts with it.
Lexi
That is correct. Hope the OP sees your correction. Clay/Lexi
