1959 or 60 Instument Panel Nut Size
Started by 60eldo, May 04, 2022, 11:47:12 AM
60eldo
  Im looking to reach up and tighten the small nut holding my gas guage on, its loose, and Im loosing ground. But I need to know the size of the socket as its very difficult getting my hand up there. So if any of you have a spare speedo siting in the garage can you please see what the socket size is for that nut  is,,,thanks
Jon. Kluczynski
Eldovert
Jon, The nut is 3/8s.. but there is a plastic cover that feels like a nut over the terminal.
Cheers,Pat MacPhail
60eldo
  Thanks ,will the 3/8 socket fit over both? Any chance you could post a pic,  really appreciate it
Jon. Kluczynski
60eldo
#3
  Is that nut from the gas guage, looks like your holding a nut and a bolt in your hand. Im a little confused
Jon. Kluczynski
Eldovert
#4
Jon, That plastic nut I am holding pops off fairly easily..at that point a 3/8 socket will fit on the steel nut.
Cheers,Pat
PS. Those are the terminals at the back of the gas gauge.
60eldo
   OK,,,Im gonna try, but I dont think I can get my 2 fingers in there to pop off that cap,,,Thanks I will try
Jon. Kluczynski
David Greenburg
If you have a/c, get the duct hose out of the way, and you should be able to get up there unless you've got really big paws.  Good light helps a lot.  I was just in mine dealing with high beam indicator.
David Greenburg
'60 Eldorado Seville
'61 Fleetwood Sixty Special
Disconnect your battery while you are trying to get a socket up there.
Use a 6 point socket.  Better fit.
