1975 headlamp switch
Started by Roger Zimmermann, July 08, 2018, 09:40:38 AM
Most probably I will have to organize a light switch for a French owner. According to the parts book, the light switch is the same, no matter if the car has the Twilight Sentinel system or not. Is that true?
Thanks for the light!
cadillacmike68
Quote from: Roger Zimmermann on July 08, 2018, 09:40:38 AM
The SWITCH is the same. The bezels, backlights, rings, etc differ on whether is has Twilight Sentinel, Guidematic, both either or none.
"Cadillac" Mike
Thanks Mike!
The information at Rockauto is sometimes misleading. If you look below, the one offered by Standard includes the part number 1995197 wich is the correct number for 1975.
•Standard is a global manufacturer of original equipment ignition products, complete quality control is maintained through the manufacturing process from componentry to finished product.
Connector Gender Female
Terminal Gender Male
Terminal Quantity 9
Terminal Type Blade
Alternate/OEM Part Number(s): 1995171, 1995181, 1995196, 1995197, 1995211, 1995224, 1995225, D1509A, D1510A, D1558, D1582, D1584, D1594, D1595, D1598, SWG1422
cadillacmike68
#3
"Cadillac" Mike
