DARK MODE THEME OPTION AVAILABLE - A user selectable Dark Mode theme and some other layout themes with color choices have been installed and are now available for all forum participants. For instructions, please see the post in the General Discussion Forum. To keep the current Light Mode theme, no action is necessary.
1959 cruise control question
Started by foxsnout, January 25, 2020, 04:46:18 PM
S_Clark
Is there a source for a socket to remove the odd torx like screws holding the 59/60 cruise unit together?
1960 Series 62 Convertible
spolij
Any decent hardware store will have torx tips that fit in a special screwdriver
S_Clark
Quote from: spolij on June 04, 2020, 09:24:44 PM
True, but these are 10 point instead of 8 and appear to be 1960 anti-tamper fasteners to keep people out so I'd assume they aren't metric.
spolij
I bought anti tamper bits from  Do it best hardware. Lowes and home depot have them also.
S_Clark
I had to get a picture. I've seen security bits at hardware stores and have 6 types in a driver set. But none like this. (pictures of the body of the '60 Cruise unit)
spolij
When you said socket and tork I got confused. That looks like a 12 point socket would work - or a pipe wrench lol. I would take it or a picture to do it best and see what they recommend. if all else fails i would use a pipe wrench.
spolij
You may also look on the net for speciality car sockets. There are a few that you may call and ask.
S_Clark
It's tiny, and curved a bit so pliers/vice grips slip off. 6 and 12 point sockets don't grip it, or inside torx.
I'd wondered if I could put saran wrap over it and cast epoxy into a slightly larger socket.
Is there such a thing as a wrench with adjustable wire pins that'll grip a bolt? I thought I'd seen something like that but can't find it now.
Searching for specialty sockets turned this up (thanks!), I think I'm going to grab the set to see if it'll work.
Quote from: S_Clark on June 06, 2020, 03:51:22 AM
There is such a socket, or sets of sockets, but never wanted to buy one, as I have sufficient of most measurements to enable me to undo any bolt/nut that I will ever find before I kark it.
It is in the centre, but size could be a problem.
https://www.google.com/search?q=pin+socket+wrench&rlz=1C1CHFX_enAU679AU679&oq=Pin+Socket&aqs=chrome.1.0l8.6196j0j8&sourceid=chrome&ie=UTF-8
foxsnout
I had the same problem. Searched for a socket with no result. I took a bent needle-nose plier and it came off really easy without damaging these little bummers. Give it a try!
Marco
1973 Cadillac Eldorado convertible
1952 Buick Super
1952 Fabulous Hudson Hornet Race Car #92
1973 Chrysler New Yorker
spolij
#30
Bruce's product should work. Now size is the question. This works great on rounded bolts.
That set of sockets are probably expensive.
Maybe there is a mechanic shop in your area that works on classics you could ask them.
Check this out   https://www.northerntool.com/shop/tools/product_200413664_200413664
Here it is in close-up.
2020 Gator Grip Universal Socket Multi Function A Hand Tool Set Repair Kit
I've had one of those in my toolbox for many years, thought it was neat when I bought it but never tried it out.  Probably should after all this time.   :)
There is a fine line between "Hobby" and "Mental Illness".  Dave Barry.   I walk that line.
1973 Cadillac Caribou - now back home as of 9/2024
Lexi
Yes, they do work well. I have one also in my tool set which is seldom used, but pays for itself when it is called upon. Think mine came from Sears years ago. Clay/Lexi
S_Clark
First, thanks for all the feedback!
I just tried some bent pliers. Mine are too tight for that trick, dammit!
I ordered one of those sockets, though it may be too big. I searched for a smaller one but the only variation I found is an even larger one that doesn't have a center gap. The head being so small, with little room around it on one side makes the specialty wrenches where pins come in from the sides too big to fit.
Somewhere there must be 8 point inside torx looking sockets in that size that the factory used though, right?
spolij
Call a shop that works on clasics. Do you belong to a local club? They may know of a shop that will help you out.
Cadillac Fleetwood
Quote from: S_Clark on June 05, 2020, 07:43:24 PM
These same fasteners with 8 points were used on the centre of the steering column lower cover on all 1963 through 1968 Cadillacs, in order to make access to the ignition switch and its wiring more difficult.  I seem to recall that the shop manuals of the time made reference to a Kent-Moore tool (KM) which was supplied to the dealership service departments.
Charles Fares
1970 Fleetwood Brougham
1969 DeVille Convertible
1989 Fleetwood
S_Clark
Quote from: Cadillac Fleetwood on June 06, 2020, 10:19:48 PM
Exactly, that is the other place I've got one of those screws. But that was was finger tight, dammit!
Is there somewhere in the shot manuals or Cadillac master parts list that'd have the Kent-Moore tool part number? I thought I'd search for that if I could find it... Everything I found in those or the National Service Data (Mitchell) manuals but everything referred to sending the cruise unit back to the factory for service. That doesn't sound promising for tool availability. Looking on Ebay I see that units from, say, '62 have normal screw heads... Frustrating!
S_Clark
Well, I got the two type of sockets without luck. I'm going to try casting epoxy before considering something that could damage the fasteners.
foxsnout
...that sounds like fun ::)...keep us updated..pictures, pictures!
1952 Buick Super
