1959 Coupe DeVille Fuel Filter Fittings
Started by Gabe Davis, September 11, 2022, 10:37:45 PM
Gabe Davis
Hi all,
I am restoring the fuel system of my '59 to its original state. I have the correct fuel filter and reproduction line to go between the filter housing and carb but am missing one last fitting.
It is the 90 degree fitting that comes out of the filter housing and allows the metal fuel line to attach.
The metal line is a 5/16 flare fitting and from what I can tell the filter housing is a straight thread 1/2-20. Does that sound correct? I spent the afternoon visiting a Home Depot and two different NAPA stores, both with helpful managers that let me dig through the Weatherhead fittings cabinets but was not able to find the correct fitting.
Does anyone know the correct specifications for this part and where I can find one? I started down the path of Grainger and Fastenal but the terms used to describe the parts are hard to search when I'm not exactly sure what I'm looking for.
The attached photo (not my car) has the part I need circled.
Any help is appreciated!
1959 Coupe DeVille
Rosewood with Dover White Top
Gabe Davis
Perhaps this one? Maybe? The type of thread into the filter housing is what I am concerned about. I don't think it is setup as a standard NPT type that is tapered shaped. It seems to be a straight thread but that elbow is MNTP (male national pipe thread).
https://www.grainger.com/product/PARKER-Male-Elbow-6JLH1
1959 Coupe DeVille
Clewisiii
I thought people were finding them as dorman fittings.
"My interest is in the future, because I am going to spend the rest of my life there."  Charles Kettering
fishnjim
Common issue w/ SAE inverted flare fittings.
straight thread on flare fittings.
Tapered thread on pipe fittings.
Adapters change from one to the other.
Check with a thread gauge or a spare tube nut(s).
Be careful because a straight will start in a taper but won't bottom out and can strip threads, if you keep tightening.
http://fittingsandadapters.com/brassae45fla.html  (scroll down)
Gabe Davis
#4
I found it!
The NAPA guy suggested I try a hydraulic shop down the street. They were happy to help but did not have the fitting. They said to try a small local auto parts store that I had not been aware of. I drove over and talked to the guy at the counter. I showed him the picture from the Grainger website. He went in the back and after a couple of minutes emerged with the fitting in hand! It is a taper and it fit perfectly into the filter housing.
I got it installed between the hard line to the carb and the filter housing. The hard line came from Inline Tube. I got the stainless steel version.
https://www.inlinetube.com/products/scae5901
This was part of a bigger project. I had the original Carter AFB rebuilt by Daytona Parts Company. They did a fantastic job. The carb looks like it is brand new right out of 1959. I installed it with a new phenolic spacer and the correct manifold-gasket-spacer-gasket-stainless plate-indian head sealer-carb stack all setup.
The car runs like a dream! I have the idle set to the correct 450rpm while in drive and she runs so smooth. I'm very pleased with how it all came out.
Thanks to you all for your suggestions and help!
1959 Coupe DeVille
Roger Zimmermann
Just a small detail: you are using rubber separators for the spark plug wires. To install them, it's necessary to cut the separator to enter the wire(s). You did the cut on the wrong side: they must be towards the bracket and not up...It makes the separator's installation easier!
1956 Sedan de Ville (sold)
1957 Eldorado Brougham (sold)
1972 Coupe de Ville
CLCMRC benefactor #101
59-in-pieces
Roger.
Eyes of the eagle.
Impressive - as are your miniature and fabrication skills.
Have fun,
Steve B.
S. Butcher
Roger Zimmermann
Thanks Steve!
I noticed the wrong side cut because I did once the error!
1972 Coupe de Ville
KingmanCadillac
#8
Nice job !
I'm not sure on the 59 60 but according to the authenticity manual for the 57 the fuel pump would be painted blue with the motor.
Tim from Daytona parts Co. Is really is a great guy
That carb looks beautiful
Thor Stone
1957 Cadillac CDV
1964 Fleetwood (Project)
1964 Cadillac SDV
1964 Cadillac CDV (Project)
1965 Cadillac CDV (Project)
1966 Cadillac CDV (Project)
1967 Cadillac SDV (Project)
1967 Fleetwood (Project)
1968 Eldorado (Project)
1972 Cadillac ELC (Project)
1972 Cadillac Eldorado
1975 Eldorado (Project)
1975 Cadillac ELC
1975 Cadillac CDV
1976 Cadillac ELC
1977 Eldorado (Project)
1981 Fleetwood BRG 2dr
