Reminder to members, please access your profile and make sure that you have created a secret question and answer. This is required to enable the system to send you a Reset Password email if you forget your password.
1953 12V Starter
Started by signart, November 21, 2022, 10:29:34 AM
signart
As subject relates, looking for a 1953 Cadillac starter motor. Not sure if '54, '55 is the same but '52 and back will not work as they would be 6V.
Art D. Woody
Bob Schuman
1954 and 55 complete starters are not the same as 1953, but some components are the same. A MPB of that vintage is needed to be sure. I do know that the armature assembly is the same for 1941 through 1953, and possibly 1940 is the same, even though those are all 6 volts through 1952. The difference was in the field coils and the solenoid assembly.
Bob Schuman, CLC#254
1951 6137
1948 Olds 98 Custom
2020 XT6
PHIL WHYTE CLC 14192
I believe you can use a 6 volt starter with 12 volts with no issues.
